Topic: complete change to the key bindings
I just updated the software and all of they keyboard bindings have changed? I have to hold alt but even then I cant play AND pause... only emergency play and the numbers 7. 6, 5 & 4 dont loop anymore.
Is there any way to change it back? because this completely screws me over I've been using this software for years I started as just a teen and (although it may be a little weird) persevered and learnt how to use it with keyboard and mouse instead of proper decks. Is this it then should I just move on or is there a way I can change the old keyboard controls back. I'd prefer to just carry on if I can, is anyone else bothered by this change?
geposted Tue 28 Sep 21 @ 7:21 pm
change your keyboard mapping to the old one factory default (legacy).
geposted Tue 28 Sep 21 @ 7:29 pm
Thanks for pointing that out it was right in front me all this time in the mapping menu. Long day, sorry. Thanks again 😅
geposted Tue 28 Sep 21 @ 7:38 pm
