How do I disable mathengine? I can't find it and I've spent quite some time looking.
Thanks.
Thanks.
geposted Fri 08 Oct 21 @ 10:11 am
geposted Fri 08 Oct 21 @ 10:17 am
Thank you soooo much. You are a star!
I love the stems feature but it degrades the sound quality, making songs sound like they are watery lower bitrate mp3s. It's subtle but I can tell. Maybe most people wouldn't notice.
I like the fact that this can be enabled and disabled without interrupting the song, providing you start with the engine at 'CPU' setting in my case.
geposted Fri 08 Oct 21 @ 10:35 am
Can't actually see whare you went wrong. Settings then just start typing math.........
I have it disabled by default too.
geposted Fri 08 Oct 21 @ 10:39 am
Note that as long as you don't use it it doesn't affect the sound at all.
So it might be easier to just use the small drop down triangle next to the eq and switch between stems and frequencies there as needed.
(personally I keep the eq on frequencies and use stems from the pads as needed)
geposted Fri 08 Oct 21 @ 10:49 am
Good advice there. Thanks all.
geposted Fri 08 Oct 21 @ 10:59 am
