Topic: New Update Problems on Roland 707M
I've been having a couple of issues since the latest update....
Using Roland 707M controller with Infinity Licence, never had issues before now.
Firstly... the Filter Knob.
Using 2 decks, filter knob on deck 1 affects BOTH outputs.... filter knob on deck 2 does NOTHING?
Secondly, the channel eq knobs would occasionally not work correctly? Sometimes they seem to change to stems settings and not revert back... more worryingly, if 'bass' is turned all the way down/off sometimes it will not turn up again when the next track is loaded on that deck! I've had occasions where I'll be playing a track on deck 1, turn the bass eq all the way down/off for a mix, load another song into deck 1, but when mixing back, deck 1 seems to be on stems mode and the lower eq knob will stay off, despite the visual onscreen showing it moving up/down as i mess with it?
I've noticed this happens a lot more often when using 'older' default skins, reverting to the default skins seems to have stopped this happening, but I don't like this skin for other reasons.
geposted Fri 08 Oct 21 @ 3:10 pm
