Had a windows crash so I had to start all over with a new VDJ install. Using home version, the space bar doesn't start the deck. Can't find any settings to fix.
geposted Sat 09 Oct 21 @ 11:54 pm
No... this is not only space bar : whole keymap and keyboard engine have silently change
you can still use old behavior by selecting map "Legacy (default)" in settings
or map space to "play_pause" again as it was in old style map
geposted Sun 10 Oct 21 @ 12:14 am
I can't find your settings. Please somebody walk me through this.
geposted Sun 10 Oct 21 @ 7:37 pm
check the mapping window, you select mapping layouts there.
geposted Sun 10 Oct 21 @ 7:55 pm
