Topic: Rane One FX Buttons Not Showing in Config
I woudl lik eto edit the effects that are selected when pressing the FX preset buttons on the Rane One controller but I do not see an option to edit what effect is triggered on fx2 through fx6 is there a way to change the FX on those buttons on the Rane One? I dont see those buttons in mapping or config to even edit.
geposted Wed 13 Oct 21 @ 2:51 pm
Thank you worked perfectly!
