Has anyone had this happen and know how to fix it?
My setup is a Reloop Beatmix 2 on an HP laptop and an Akai MPD218. Something is cause the rotary encoders that I have setup to control the effects with both adjustable effect perimenters to jump and act jittery which makes the levels change so they are not where I left them from the last time I used them. None more important than the one setup as the color effect set to filter. My belief is that I have all new cables and things are connected as it's supposed to be. What could get into the midi code to make them jump and jittery? The controller and the Akai are USB powered, so could I be running out of power even though the laptop is always connected to the charger.... #stumpted
Thanks for the help...Dan
geposted Fri 15 Oct 21 @ 9:35 am
