Based on a question I got on YT I tried moving a RB database to an external drive (which is an option in RB) to see what VDJ then does
It appears than VDJ then still reads the left behind (for some reason?) RB database in the \AppData\Roaming\Pioneer\rekordbox folder, even though that is not "the active one" if you will
Is this correct?
Is this correct?
geposted Sun 17 Oct 21 @ 11:06 am
anyone figure that out???
geposted Thu 19 May 22 @ 6:02 pm
VDJ indeed only looks in the AppData\Roaming folder for the rekordbox database.
geposted Fri 20 May 22 @ 5:06 am
