Hello! I've been experiencing some weird delay between the top main waveform needle and the sound output when my music's playing. It seems as if the sound comes a bit later than the current point the needle is marking at the main top waveform...I have tried reducing the latency of my VDJ and DDJRB ASIO drivers (up to 256), changing the fps of my skin, but none of those seem to have worked. It's ticking me off a bit because looping and other stuff gets harder since I can't trust the visual feedback the software gives me..The audio always comes a bit later than what the needle is marking, so it's kind of annoying.
Can anyone help me with that? Any suggestions?
geposted Sun 17 Oct 21 @ 12:48 pm
Do you use any "MASTER" audio effects ?
geposted Mon 18 Oct 21 @ 9:38 am
