i have a license for my hercules MK4 can i use it on an older hercules dj console?
geposted Mon 18 Oct 21 @ 3:37 am
Unfortunately no, controller licence is for specific model only.
geposted Mon 18 Oct 21 @ 5:48 am
Thanks for the answer
geposted Tue 19 Oct 21 @ 6:13 pm
I have an VirtualDJ 2020 Home PLUS License for DJCMK4 I would like to buy an hercules starlight controller, can I play with that new combination WHITHOUT an internet connection? If the answer is YES what do I have to do to make it work? (change controller product number?) the old controller is absolete.
geposted Tue 20 Feb 24 @ 7:32 am
As mentioned above, the PLUS license is for a single controller.
You'd need either a PRO license, or another PLUS license for the new controller.
You will indeed be able to use it without an internet connection. If you go for the Pro subscription you'd need to be connected to the internet once a month to validate the license.
geposted Tue 20 Feb 24 @ 7:52 am
OK got it
geposted Tue 20 Feb 24 @ 8:26 am
