Hi,
I'm looking for a good heads up display that integrates well with with virtual DJ.
The requirements are seeing big waves in it and loading tracks from it.
The ideal would be the Numark Dashboard - that's exactly what I was after, but it's discontinued and impossible to find.
At the moment I'm using the SC5000s for this, but I'd want it just for vynil timecode and they are taking too much space.
Any other device with a nice display that you could recommend?
Thanks
Thanks
geposted Wed 20 Oct 21 @ 10:02 am
AFAIK Numark Dashboard is not a heads-up-display, it's still heads-down-display. Or where ever the display is positioned: down, up, side to side. Heads-up-display is what's in jetfighters or ironman movies in which you can see the display without taking your eyes off of what's happening in front of you, you don't have too look down to the display. You can keep your "heads up".
geposted Sat 23 Oct 21 @ 8:54 am
I think what you want is either an external (extended) display, or google glass VR type of display.
geposted Sat 23 Oct 21 @ 9:02 am
you could use a android or ipad tablet with the remote app
geposted Sat 23 Oct 21 @ 1:37 pm
