Forum: Wishes and new features
Topic: Prelisten: add "Stop on load"
The prelisten has an option to "stop on change", which stops the prelisten when the song changes.
It would be handy to stop the prelisten automatically when the song is loaded.
Example of workflow:
- with the prelisten set to use "Listen on: automatic" channel, the user enters the browser and prelistens some tracks.
- as per "Listen on: automatic", the prelisten will happen in a channel that is stopped and ready to be loaded.
- the user finds the song and loads it.
- the prelisten stops and the user can start mixing it in the same channel it was prelistenen, which will be on PFL by this time.
This would be specially handy when loading tracks from controllers, where stopping the prelisten manually is normally impossible.
geposted Thu 21 Oct 21 @ 9:48 pm
add it in to your ONSONGLOAD entry
