Hi Guys can you please help . My right deck on my pioneer controller pitch is set to zero but on the virtual DJ screen it’s showing at -1.7 . I then set it back to zero on virtual DJ but it jumps . It’s constantly changing . This only happened on the right deck . Any help would be appreciated. I’m using a Pioneer DDJ FLX6 and windows 10 thanks
geposted Fri 22 Oct 21 @ 11:00 am
Sounds like you have an auto option enabled on the deck
Have you set all the auto options how you want them?
geposted Fri 22 Oct 21 @ 11:52 am
