I have the most recent update of VDJ and continue to have very distorted recordings of all of my mixes. The sound is over-modulated and when two songs are mixed together, it is even worse. Splatter, splatter, splatter.
I have tried every adjustment and every setting change possible but, no luck on correcting this issue.
All other music that was not recorded in VDJ sounds great. I go from controller straight to laptop via USB so no dual sound cards.
Does anyone have any recommendations or solutions.
My controller is a Pioneer DDJ-SX1 but I also use the 3.
geposted Sun 24 Oct 21 @ 7:30 pm
sounds like a gain issue?
how is autogain set?
do you use internal or external mixer?
geposted Mon 25 Oct 21 @ 12:17 pm
Auto gain is selected.
geposted Wed 27 Oct 21 @ 10:55 pm
No internal or external mixer is being used, only the controller.
geposted Wed 27 Oct 21 @ 10:56 pm
Try setting zerodb in options to -6
geposted Thu 28 Oct 21 @ 12:24 am
Will do and will post how it goes. I do remember seeing an adjust for recording levels but don’t remember how I got to it. It was a lot of right-clicking and I found it. Not sure if it was a VDJ setting or Windows.
geposted Thu 28 Oct 21 @ 2:51 am
