Topic: Pitch slider action - way to map it to smaller increments?
Hi, I have a wheel on a controller that I'd like to use to alter the pitch. I'm using "deck 1 pitch", but the increments when I turn the wheel are too big. I'd like it to move by just 0.1 each time.
I can't find a way to do this, though. If I make the mapping "deck 1 pitch +0.1%" then it only goes upwards, even if I move the wheel the other way. Is it possible to make it so that it goes up or down by a specific smaller amount like that?
geposted Sun 24 Oct 21 @ 10:29 pm
you can test whenever the value is positive or negative
deck 1 param_bigger 0 ? pitch +0.1% : pitch -0.1%
or reduce the value
deck 1 param_multiply 0.3125 & pitch
