Noticed recently even though I have autoSearchDB set to no videos I edit on my desktop are appearing in VirtualDJ database.
When I manually add to database I select my D: video drive and the desktop is on C: so no explanation for this happening
geposted Mon 25 Oct 21 @ 6:31 pm
autoSearchDb only prevents files from showing up automatically in searches, it does not prevent files from being added to the database.
geposted Mon 25 Oct 21 @ 6:45 pm
That's not what the description says .... and it's only started happening recently.
I also haven't been browsing those folders from within VDJ either.
geposted Mon 25 Oct 21 @ 6:51 pm
"to the search database"
So you are saying this files do come up in search? Or where else do you see them in the database?
geposted Mon 25 Oct 21 @ 7:14 pm
Apologies, I've just figured it out.
To edit the files and upscale them I have been using the "file operations, copy to" to place them on the desktop, and that must be when VDJ creates the duplicate DB entry.
geposted Mon 25 Oct 21 @ 7:17 pm
Ah indeed, copy copies the database entry as well
geposted Mon 25 Oct 21 @ 7:21 pm
Mystery solved, thanks!
geposted Mon 25 Oct 21 @ 7:25 pm
