Topic: Halloween or Video Loops Not Displaying
Hello: The video extensions loops like the Halloween or the shadow girls does not display on the screen. It used to. I have the Pioneer Controller DDJ-SR2 and the MacBook Pro for your reference. Oh by they way. It works, BUT as soon as I connect my controller, it does not display. But the music video works just fine. Please advise. Much appreciate. I would like to use the effects for the upcoming Halloween week-end.
geposted Thu 28 Oct 21 @ 5:52 pm
NicotuxHome userMember since 2014
That's due to padpage page being not the same with keyboard and controller
(yes these are called padpages of padpages)
maybe try to use padSkinIndependent
geposted Thu 28 Oct 21 @ 6:44 pm
That worked.. Thank you. First I turn it on and then turn it off and bam... it is showing and working with my controller.
geposted Fri 29 Oct 21 @ 6:50 pm
Hello Tech Support. My video loops are not displaying again. I did go to pad skinner and turn on and off or just on and nothing is displaying with my Pioneer Controller DDJ-SR2. It worked before now it does not. It does show when I am just using my MacBook Air only. Please advise. Much Appreciate it and Happy Holidays. I look forward to your response.
geposted Tue 28 Dec 21 @ 8:25 pm
