Can you quick filter out tracks based on color? I’m able to set a filter by color, but every time I reopen the quick filter options the color section is blank.
Then it’s seems to filter out tracks that are not associated with that color…
Specifically, any track I want to weed out I color black so I’ve got a condensed library with no instrumental, acapella, etc
Is this maybe because I have a color filter that makes “already played” tracks black?
Or is it something to do with the color style (gradient, system, etc)?
geposted Thu 28 Oct 21 @ 6:00 pm
quick color comes after quick filter therefore if you want to exclude tracks use a quick filter with whatever you params used to quick color the tracks.
Or actually hard color those tracks then yes you can filter out by color [quick filter not quick color]
geposted Thu 28 Oct 21 @ 6:17 pm
