Topic: Crash on startup
I never had any problem with VDJ on my MBP, but now it crashes on startup. When I click the icon in the dock it bounces once or twice, a second VDJ -icon appears bouncing in the dock and then they both stop.
I deleted the app and reinstalled it with the latest version, updated Catalina, unplugged my (licensed) DJ-console and restarted numerous times.
I don't what else to do, please help!
I can send a crash report if I knew how.
Peter
geposted Fri 29 Oct 21 @ 8:54 pm
I found a solution in another topic concerning VDJ not starting after updating macOS Catalina. But it's an ugly solution: rename the file settings.xml in the directory Documents\VirtualDJ.
So now I have to do all my custom settings again??
You can try to set experimentalUseMetal to yes manually in the old settings file
