My sound is low on the left side though everything is set to max
geposted Sun 31 Oct 21 @ 4:01 pm
make sure master_balance is 0.5 and no balance effect is running
test physical connections - swap right and left if possible - to verify this is not a hardware issue
Verify audio settings - may need infos about OS and hardware as well as a screenshot of VDJ audio config to get some more precise help
geposted Sun 31 Oct 21 @ 6:29 pm
thank you
geposted Fri 12 Nov 21 @ 2:04 pm
