Topic: Virtual DJ ignoring some tracks after renaming them.
Hi
I have an issue where some tracks are not appearing in Virtual DJ. It is partly my fault as sometimes I get a newer or extended version of a song & rather than create a new file and start from scratch in my playlist, i normally use Virtual DJ to rename the 'old' file to be the same name as the 'new & improved file' then overwrite it.
i.e. when i get an extended version of a song
"Kylie Minogue ft Years & Years - A Second To Midnight (HD).mp4" gets renamed to
"Kylie Minogue ft Years & Years - A Second To Midnight (Extended Edit) (HD).mp4"
Then i copy the new (Extended Edit) file over the old one to replace it on my drive.
This way, Virtual DJ will think it is the same file and I will get it appear in recent played & in my file history etc. Virtual DJ renames it and corrects all my playlists so that is great.
However occasionally during a backup sync I have mistakenly copied the some of the old files back on to my computer so that there are both versions present on the drive, this in itself is not a problem except that Virtual DJ will not see the old version of the file with the original filename when searching or even when browsing a folder, it totally ignores it as if it is not on the hard drive.
Both files are in the database as listed below.
<Song FilePath="O:\Chart\Kylie Minogue ft Years &amp; Years - A Second To Midnight (HD).mp4" FileSize="48877901">
<Tags Author="Kylie Minogue ft Years &amp; Years" Title="A Second To Midnight" Remix="HD" Flag="2" />
<Infos LastModified="1635523944" FirstSeen="1634908945" />
</Song>
<Song FilePath="O:\Chart\Kylie Minogue ft Years &amp; Years - A Second To Midnight (Extended Edit) (HD).mp4" FileSize="57867037" Flag="64">
<Tags Author="Kylie Minogue ft Years &amp; Years" Title="A Second To Midnight" Genre="Gay; Celeb; Australian; Mixes; Music Video" Album="mv WeMix HD" Composer="Olly Alexander; Ollie" Remix="HD" TrackNumber="90" Year="2021" Stars="3" Flag="1" />
<Infos SongLength="222.890667" LastModified="1635636842" FirstSeen="1633701717" FirstPlay="1633702161" LastPlay="1635636842" PlayCount="8" Bitrate="2065" Cover="2" />
<Comment>Extended Edit</Comment>
<Scan Version="801" Bpm="0.491814" AltBpm="0.368855" Volume="1.212843" Key="Gm" Flag="32768" />
<Poi Pos="-0.002018" Type="beatgrid" />
<Poi Type="automix" Point="realStart" />
<Poi Pos="222.330667" Type="automix" Point="realEnd" />
<Poi Type="automix" Point="fadeStart" />
<Poi Pos="222.250" Type="automix" Point="fadeEnd" />
<Poi Pos="0.488345" Type="automix" Point="cutStart" />
<Poi Pos="222.029206" Type="automix" Point="cutEnd" />
<Poi Pos="0.491111" Type="automix" Point="tempoStart" />
<Poi Pos="205.079864" Type="automix" Point="tempoEnd" />
<Poi Pos="-0.006208" Num="4" Type="cue" />
<Poi Pos="7.851979" Num="1" Type="cue" />
</Song>
Virtual DJ only lists the (Extended Edit) version of the song even when browsing a folder.
It is not a massive problem because I can use other methods to weed out any duplicate files however I just wondered if anyone knew why this was happening. The file is on the drive, I have right clicked the drive and selected "Batch/Add to Search DB" and both files are in the database but only the newer one shows up.
Thanks anyway
Krys
geposted Sun 31 Oct 21 @ 4:14 pm
Hi
Is anybody able to help with this issue, I have since found out that Virtual DJ is completely ignoring some files in my database and will not show them in even when browsing the folder they are in.
I have no idea how many files are doing this as there is no way to find out, however here is an example of a file I knew I had on the hard drive (by checking in File Explorer) but Virtual DJ wouldn't show.
It appears twice in the database, the second occurrence is the correct one as I had moved the file at some point.
at Line 2817:
<Song FilePath="O:\Party\JSTO - I Just Wanna Dance.mp4" Flag="17">
<Tags Flag="2" />
<Infos LastModified="1636137894" FirstSeen="1636137892" />
</Song>
at Line 81701:
<Song FilePath="O:\Classics\JSTO - I Just Wanna Dance.mp4" FileSize="165239807">
<Tags Author="JSTO ft Alison Jiear" Title="I Just Wanna Dance" Genre="Explicit; Mixes; Soundtrack; Music Video" Album="mv DJK HD" Composer="DJK Audio Remastered; Manny Patel Video Edit; I Just Want To Fucking Dance; Jerry Springer The Opera" TrackNumber="90" Year="2004" Stars="5" Bpm="0.447761" Key="Am" Flag="2" />
<Infos SongLength="317.579320" LastModified="1637433875" FirstSeen="1314983100" FirstPlay="1315084380" LastPlay="1632698434" PlayCount="175" Bitrate="4157" UserColor="4292861696" />
<Comment>Wayne G Lady Botox Radio Edit</Comment>
<Poi Pos="0.718367" Type="beatgrid" />
<Poi Name="Cue 1" Pos="65.197755" Num="1" Type="cue" />
<Poi Name="Cue 4" Pos="11.461859" Num="4" Type="cue" />
<Poi Pos="0.058050" Type="automix" Point="realStart" />
<Poi Pos="314.483810" Type="automix" Point="realEnd" />
<Poi Pos="48.250" Type="automix" Point="fadeStart" />
<Poi Pos="314.150" Type="automix" Point="fadeEnd" />
<Poi Pos="68.374785" Type="automix" Point="cutStart" />
<Poi Pos="314.130431" Type="automix" Point="cutEnd" />
<Poi Pos="72.365941" Type="automix" Point="tempoStart" />
<Poi Pos="300.266531" Type="automix" Point="tempoEnd" />
</Song>
Does anyone know why this file doesn't appear in search or when browsing. I have manually removed these entries from the database and then when I "Add to Search DB" it finds it and everything is OK but I don't know what other files may not appear that are on my drive so would love to find the cause so I can check my DB file properly.
Thanks
HI
Having had a good look at my database and some files do not have a "flag" entry within the <song> item, it appears Virtual DJ will not show these files under any circumstances.
I recently upgraded my PC and did a database backup from the old laptop and restored it onto my new one thinking this was the correct thing to do, during this process, a whole bunch of music videos (100s) were added to the database without the "flag" entry and do not show up on my new laptop. I corrected the problem by simply copying over the database.xml from my old laptop (as the music was in the same location) on my new laptop, however I thought you should be aware of this.
This only seems to affect videos, as I have mp3 with not "flag" entry that Virtual DJ shows no problem
