laptop fujitsu siemens 2010 , 4gb ram with win 10 pro . with vdj 2020 i was more than 12 months with no problems at all , just one day last summer , it stuck for seconds , i played a video from you tube , reopen vdj and no customer found out a thing... 3 weeks ago in october '21 i installed 64bit in pc in order to work 8gb memory (it never worked) and vdj 2021 64bit.. WELL IT STUCKS EVERY DAY . i put back 2020 32 bit played for some hours and no problem. thats my experience .
geposted Mon 01 Nov 21 @ 9:33 pm
Yes on a laptop that old you may want to stick with a 32-bit setup
If you choose to go 64 bit OS, and install VDJ2021, you probably need to disable the stems separation feature by setting mathEngine to disabled
geposted Mon 01 Nov 21 @ 10:15 pm
thanks
geposted Tue 02 Nov 21 @ 7:24 pm
