Hello everyone,
I ask for advice to understand if what I would like to do is possible. I assigned these different panels in the new Vrtual DJ live skin, written in this order, only the last 3 panels (Vocal, Melody, Rhythm) will be displayed correctly when I press the pad of the relative stem, the first 5 will display incorrect names and added to the names of the other pads dedicated to stems. If I reverse the order in the XML file by placing the Vocal, Melody, Rhythm and the other 5 panels first, the 5 panels will be displayed with the correct names and the first three with the wrong names. In practice, only the panels written in the second block in writing order are displayed correctly. Now since there is no "get_stem_name" function, I was wondering if it is possible to make these two panel blocks independent of each other so that they are all displayed correctly when their respective stem pads are pressed.
To reduce the post I don't write everything about the names and positioning of the panels but only what should make them visible:
<define class="stemspanel">
<group name="stems_pads" visibility="mute_stem 'vocal' ? on : off ">
<group name="stems_pads" visibility="mute_stem 'instru' ? on : off ">
<group name="stems_pads" visibility="mute_stem 'bass' ? on : off ">
<group name="stems_pads" visibility="mute_stem 'kick' ? on : off ">
<group name="stems_pads" visibility="mute_stem 'hihat' ? on : off ">
</define>
<group name="stems_pads" visibility="only_stem 'vocal' ? on : off ">
<group name="stems_pads" visibility="only_stem 'melody' ? on : off ">
<group name="stems_pads" visibility="only_stem 'rhythm' ? on : off ">
</define>
<item class="stemspanel" visibility="is_using 'stems' 1000ms"></item>
Thanks to those who can give me an answer.
</define>
</define>
geposted Tue 02 Nov 21 @ 11:46 am
If you define two or more classes with the same name, only the latest one gets loaded by the skin engine (actually the second instance overwrites the first)
Therefore I believe you just need to rename your classes to have unique names
geposted Tue 02 Nov 21 @ 1:08 pm
Yes, I imagined it, in fact, I did all the tests I thought possible, but, if I name the first block, for example
<define class = "stemspanel1">
and the second
<define class = "stemspanel2">
I also have to create
<item class = "stemspanel1" visibility = "is_using 'stems' 1000ms"> </item>
<item class = "stemspanel2" visibility = "is_using 'stems' 1000ms"> </item>
and in this case I will have displayed two panels at a time on the live skin because they both use is_using 'stems' and both only stem and mute stem are related functions.
Can this be solved? Thanks PhantomDeeJay
geposted Tue 02 Nov 21 @ 2:01 pm
Can anyone give me any other advice or tell me if what I would like to do is possible?
Thanks
Thanks
geposted Wed 10 Nov 21 @ 12:32 am
I'm not sure after what you're trying to achieve here.
Mostly because everything can be simplified like this:
In other words, since the individual groups are not meant to be shown together they can be combined.
Another way (depending on what your skin looks like) could be this:
<group name="stems_pads" visibility="mute_stem 'vocal' ? on : off "/>
<group name="stems_pads" visibility="mute_stem 'instru' ? on : off "/>
<group name="stems_pads" visibility="mute_stem 'bass' ? on : off "/>
<group name="stems_pads" visibility="mute_stem 'kick' ? on : off "/>
<group name="stems_pads" visibility="mute_stem 'hihat' ? on : off "/>
<group name="stems_pads" visibility="only_stem 'vocal' ? on : off "/>
<group name="stems_pads" visibility="only_stem 'melody' ? on : off "/>
<group name="stems_pads" visibility="only_stem 'rhythm' ? on : off "/>
</define>
<item class="stemspanel" visibility="is_using 'stems' 1000ms"/>
<panel name="mute_stems" visible="mute_stem 'vocal' ? on : mute_stem 'instru' ? on : mute_stem 'bass' ? on : mute_stem 'kick' ? on : mute_stem 'hihat' ? on : off">
</panel>
<panel name="only_stem" visible="only_stem 'vocal' ? on : only_stem 'melody' ? on : only_stem 'rhythm' ? on : off">
</panel>
</define>
geposted Wed 10 Nov 21 @ 9:23 am
</define>
</panel>
</panel>
</define>
Thanks PhantomDeeJay for your time. In addition to the solutions I tried, I just tried the one you suggested, unfortunately the result does not change the names of the stems are always overlapped and this time no group (isolate, remove) appears with the correct names.
here are the complete commands:
<size width="370" height="170"/>
<square class="panelback"></square>
<square class="bigpad"></square>
<visual>
<pos x="+25+30-15" y="+25+30-15"/>
<size width="90" height="90"/>
<off x="681" y="31" width="90" height="90"/>
</visual>
<textzone>
<pos x="+170" y="+55"/>
<size width="160" height="30"/>
<text fontsize="22" align="left" weight="bold" color="brighttext" text="VOX"/>
</textzone>
<textzone >
<pos x="+170" y="+55+25"/>
<text fontsize="20" align="left" weight="" color="darktext" text="Remove"/>
</textzone>
</group>
following the groups instru, bass, kick and last hihat then:
<visual>
</visual>
<textzone>
<text fontsize="20" align="left" weight="bold" color="brighttext" text="HIHATS"/>
</textzone>
<textzone >
</textzone>
</group>
</panel>
then continuing with the groups of isolated stems:
<visual>
</visual>
<textzone>
<text fontsize="20" align="left" weight="bold" color="brighttext" text="VOX"/>
</textzone>
<textzone >
<text fontsize="20" align="left" weight="" color="darktext" text="Isolate"/>
</textzone>
</group>
following the groups melody, and last rhythm then:
<visual>
</visual>
<textzone>
<text fontsize="22" align="left" weight="bold" color="brighttext" text="RHYTHM"/>
</textzone>
<textzone >
</textzone>
</group>
</panel>
</define>
Here are some examples of how stem names appear in the live skin panel:
geposted Thu 11 Nov 21 @ 11:05 am
It look like you wanna display independently things that depends on each other
only stem mutes/unmutes other, but stems are not switches only they are levels
MeloVocal, Melody, Rhythm are multiple stems at a time
what you may try is to use pad to detect which one was pressed and test stem to get status after that
pad_pushed 1 ? mute_stem 'vocal' ? on : off
pad_pushed 2 ? mute_stem 'instru' ? on : off
and for umute
pad_pushed 1 ? mute_stem 'vocal' ? off :on
pad_pushed 2 ? mute_stem 'instru' ? off : on
same apply to only_stem
this won't work with sliders
and for umute
geposted Thu 11 Nov 21 @ 3:51 pm
and for umute
and for umute
That's right, that's why I was trying to understand if it is possible to make the display of the two stem panels independent. I will also try your advice. Thanks
geposted Thu 11 Nov 21 @ 9:52 pm
