Does anyone know of a controller/mixer that has a separate Zone or Booth volume control output so I can run monitors or subs on their own volume control?
geposted Tue 02 Nov 21 @ 4:53 pm
Denon MCX8000. Works extremely well with VDJ. EQ on the booth out as well.
I have a Bose F1 sysem and use the master out for the subs and the booth out for the tops. Sweet!
geposted Tue 02 Nov 21 @ 6:09 pm
Roland 707m has Main, Booth and Zone. Each with separate Loudspeaker presets and Microphone routing.
When playing in the same Locations you can save this in 10 scene presets.
Up to 4 Mic inputs, or 3 + external input for Guests. 2 USB inputs like Denon DJ MC7000 switchable live in gig.
Weight: 7.75lb / 3.52kg
Depth: 13.2" / 33.53cm
Width: 18.7" / 47.5cm
Height: 3" / 7.62cm
Thats my controller i'm using on events. Very happy with it - but it has a few cavets to know.
Height: 3" / 7.62cm
geposted Tue 02 Nov 21 @ 7:32 pm
Height: 3" / 7.62cm
Height: 3" / 7.62cm
Cool thanks! I just watched a tutorial on the 707m. It looks like it has everything I need. One thing I did not see was pitch-bend... How do you pitch bend?
Thanks!
geposted Wed 03 Nov 21 @ 4:34 pm
@JIMMYDEEDJ
Try a look at the HW Manual https://www.virtualdj.com/manuals/hardware/roland/dj707m/layout/decks.html.
You can use the jog to pitch bend in bend mode. Just as on a vinyl platter.
geposted Thu 04 Nov 21 @ 3:49 pm
proart wrote :
@JIMMYDEEDJ
geposted Thu 04 Nov 21 @ 5:51 pm
