I have attempted to download any version of virtual dj for mac. My OS is Catalina and I just did an update last night. Prior to the update, virtual worked great. After the update, I couldn't and still cannot open the program. I have a Pro Infinity account, am an active DJ and need to reactivate the program ASAP. Please help.
geposted Wed 03 Nov 21 @ 3:33 am
geposted Wed 03 Nov 21 @ 4:12 am[ selected best answer by Adion on Fri 05 Nov 21 @ 7:43 am ]
Did you try EA build 6747 from https://www.virtualdj.com/download/build.html ?
Selected as best answer geposted Wed 03 Nov 21 @ 4:12 am
I have had no success with your suggestion, but thank you.
geposted Thu 04 Nov 21 @ 3:59 am
Looks like this was indeed not working all the time yet. A fix will be available shortly.
In the meantime you can rename Documents/VirtualDJ/settings.xml before starting VDJ. That should also fix it.
geposted Thu 04 Nov 21 @ 5:00 am
Hi All,
I am facing the same issue. I cannot open the Virtual DJ application after my latest OS update (Catalina 10.15.7). Has anyone managed to resolve this issue?
geposted Thu 04 Nov 21 @ 9:20 pm
read the above thread.
And also this thread:
http://www.virtualdj.com/forums/243969/VirtualDJ_Technical_Support/my_virtual_dj_won_t_launch____.html
both discuss a solution till, the next update fixes it more seamlessly.
geposted Fri 05 Nov 21 @ 7:38 am
EA build 6747 should be fine to fix it
geposted Fri 05 Nov 21 @ 7:43 am
Thank you so much for all the help. I just finally had the time to try your suggestion and yes it did work. Virtual is back online and everything works. Thanks again.
geposted Sun 07 Nov 21 @ 2:15 am
