Hi guys,
is it possible to put the area "rhytmzone" in an external window?
Just like the "external floating (browser) window".
I want to use this for another screen.
For the browser and 4 decks I have already found a way here in the forum.
If I now take the area of the "rhytmzone" something is also displayed.
Problem: The "wave" then overlaps when playing.
After loading a song, I have a super wave.
When I play the song, everything stops in the window and it runs into chaos.
It looks like you're drawing a (big) line. The wave becomes a "superimposed bar".
So, the areas move and they still stop.
Hard to explain...
I try the "Default Skin Pro".
The crowning glory would be when I also manage to adjust the height of the wave.
Basically, I would like to have the height over half the screen.
The wave should then be displayed on a 10 inch screen.
Many thanks in advance to all who have tips for me.
(Thanks also to google's translator)
Apart from that,
a "WYSIWYG" editor for the skin area would be awesome.
Just drag and drop, click on color, select buttons, etc...
Wishful thinking
Hard to explain...
Apart from that,
Wishful thinking
geposted Wed 03 Nov 21 @ 11:50 am
completed
solution found
solution found
geposted Tue 16 Nov 21 @ 12:17 am
