Hello,
A long time ago I bought a controller with Virtual DJ LE v 7.1.
Now I change a laptop with MACOS x64 and I can't run VirtualDJ LE - i've got a message that I can't run the application. I found that it is compatibility version (app is x86, OS is x64).
How can I run my controller with my new laptop?
geposted Thu 04 Nov 21 @ 8:10 am
Use VDJ 8, which has been available since 2014. VDJ 7 is no longer supported.
geposted Thu 04 Nov 21 @ 6:50 pm
Great idea, but I use VDJ7 with controller (Reloop Beatmix). My VDJ7 LE key isn't work in VDJ8 :(
geposted Fri 05 Nov 21 @ 7:49 am
I guess you will need to buy a new license to support your upgraded computer then. The LE versions were only ever meant to be a "taster" for the full software with limited lifespan.
That's the way of the world unfortunately.
geposted Fri 05 Nov 21 @ 9:59 am
Visit reloop dot com
search 4 your Beatmix
find downloads
find what you need
if nothing there 4 your OS - buy a new license.
(or downgrade you OS)
find downloads
find what you need
geposted Fri 05 Nov 21 @ 1:37 pm
