Hi everyone,
I just installed Virtual Dj (not connected to any deck yet, just discovering the software on my unit) and I have already noticed that once the application is closed and opened back the cue points I had set in the previous session are now gone.
I am not talking about hotcues, but just regular cue points.
is there a way to make sure those are somehow saved and called back anytime?
I am browsing from itunes playlist via internal browser but I don't think that's the point
thanks
thanks
geposted Sat 06 Nov 21 @ 1:58 pm
want to save it, use hotcues.
geposted Sat 06 Nov 21 @ 3:18 pm
No the temp cue points are not stored
You can of course "script your way out of that" if you like - but then the temp cue will take up a hot cue spot, so probably not really recommended
Here is an example:
geposted Sun 07 Nov 21 @ 5:51 am
thanks very much for your reply
geposted Mon 08 Nov 21 @ 4:10 pm
