Hi, In previous versions, I would use the following:
auto_crossfader 2000ms 0%
However, the current version seems to be ignoring the fader position percentage. Any way round this?
geposted Tue 09 Nov 21 @ 10:08 am
I think you are correct.
I also think it's and old "left over script" where most people will now use
mix_now
or
mix_now 1000ms
or
mix_now_nosync
which does a bit more, but doesn't have the fader position percentage
auto_crossfader 50%
still works though
geposted Tue 09 Nov 21 @ 10:43 am
works fine here on a custom button
geposted Tue 09 Nov 21 @ 11:30 am
Mix_now seems to control automix if that is being used. So can't be used for the functionality of fading to other deck which the auto_crossfader worked perfectly for.
I hope it's not "left over"
geposted Tue 09 Nov 21 @ 12:12 pm
For me too now - I have no Idea why it didn't before (tested using auto_crossfader 2000ms 50%)
geposted Tue 09 Nov 21 @ 4:19 pm
Weirdly it works for me on a custom button, and since added there it also works on a keyboard shortcut. Same code. Thanks for you help.
geposted Tue 09 Nov 21 @ 11:02 pm
