This would solve all my problems with cross-library management that i've ever had.
I found the CDJ export feature of VDJ to be unreliable, and it can't export a nested playlist structure without a lot of work, so for now i still need to manage my library in Rekordbox to be able to play on CDJs.
geposted Wed 10 Nov 21 @ 8:06 pm
If that's simply not a feature of the Rekordbox library support right now, is it planned?
geposted Sat 13 Nov 21 @ 12:45 am
It's indeed not supported right now, but we'll have a look if it's possible
geposted Sat 13 Nov 21 @ 4:54 am
here is an alternative if you really need this
pretty sure you can transfer library over for free but if you want to use the cloud feature it costs
https://www.mixo.dj/
geposted Sat 13 Nov 21 @ 12:42 pm
Thanks a lot for the replies! I'm really looking forward to native support! (BPM Grid support would also be amazing! I have all my tracks gridded in Rekordbox)
With Waveforms, they probably use a different format and it's not as easy or even impossible to convert, but VDJ is so fast at generating those, i don't think there's a big need for that.
geposted Mon 06 Dec 21 @ 9:12 pm
The current Early Access release of VirtualDJ can import cue points from your rekordbox library.
geposted Tue 07 Dec 21 @ 5:21 am
