Topic: Rane ONE volume fader issue
Hello,
I have a recently purchased Rane ONE controller that I've been having loads of fun with. However, there is an issue with Virtual DJ and the volume faders. They don't actually "fade" the volume as they're supposed to. I can slide the fader up and down and the volume is still 100%, unless it's at the very bottom where it's at 0%. Oddly enough, it worked correctly for me most of yesterday, but perhaps I pressed something by accident and enabled/disabled some kind of setting that I'm unaware of. Now it's back to just an on-off switch for volume again. So until I can have this issue fixed, I have to rely on the gain knobs for adjusting the volume of each deck.
I know this is a Virtual DJ issue because when I tested it out on Serato DJ, and the faders will successfully fade between 100% and 0% (volume adjustment), rather than just switching it between 100% and 0% (on/off).
I'm wondering how to fix this on Virtual DJ. All help is greatly appreciated.
geposted Thu 11 Nov 21 @ 6:55 pm
This fixed it! Thank you so much.
This is my first professional grade DJ controller, so there's a lot I have to learn. Thanks again.
