Hi friends, I was disappointed to discover I was not able to upload a podcast, I have the FULL PRO Version VDJ2021 PC64 build 6613.1818. I keep getting error messages "can't create podcast" or the "time indicator" for uploading is stuck on 0:00.
Thanks guys..hopefully VDJ will get this "bug" fixed.
geposted Mon 15 Nov 21 @ 7:12 am
might have been fixed already, build 6613 is 5 builds ago for public release.
geposted Mon 15 Nov 21 @ 7:56 am
Tech support gave me the "software" fix instructions...I've updated to the newest version and reset the "settings.xml", it's working now.
If anyone else is having problems uploading, the fix is: Go to Documents Folder > Virtual DJ Folder and move or delete the "settings.xml" file, it resets the software, and doesn't affect your database files..hope this helps everyone who was having the same problem I was having. Jeff :)
geposted Thu 18 Nov 21 @ 3:16 am
so every time i hit the pod cast button it starts and stopps after 2 seconds ? ive updated resrated and also re down loaded. v dj ive tired everthing i can possibly think of. to fix it i really need to be able to stream this weekedn for a big wedding if you can help me fix this issue. id greatly apreciate it.
geposted Thu 21 Mar 24 @ 7:56 pm
It's been fixed in the latest EearlyAccess version that was just released
geposted Thu 21 Mar 24 @ 9:24 pm
