Hi! So really enjoying vdj, but I need to export my playlist/what's playing to my website. Is there an easy way to do that? When I'm not live my broadcaster does that, but when I'm live, I'm in vdj and need how to do it from there. Any advice really appreciated!
geposted Mon 15 Nov 21 @ 9:04 pm
I made a plugin that sends metadata over HTTP, but there's also the last line of
....\VirtualDJ\History\tracklist.txt
if you want to keep it simple.
Please elaborate on "send playlist" as it could mean a few things, be specific.
geposted Mon 15 Nov 21 @ 11:23 pm
Hi and thank you! Sorry - i am doing internet radio and to be DMCA compliant you have to publish on a website (I think) music you've played and are playing. I didn't know if vdj was set up to do that already, or if I had to create a link myself. This is for when I'm live (which is when I would use vdj!)
thanks again!
thanks again!
geposted Tue 16 Nov 21 @ 4:13 pm
ah right then probably
will be all you need, you can format what is logged with setting trackListFormat
I can give hints and tips to layout, I use
\n`get_filename`
\n`get_filename`
geposted Tue 16 Nov 21 @ 4:51 pm
