Topic: deks A&B
since the latest update. If I choose A or B on a Denon sc6000, the other always changes with it. separation not possible? using with x1850.
geposted Tue 16 Nov 21 @ 8:20 am
user24521956 wrote :
since the latest update. If I choose A or B on a Denon sc6000, the other always changes with it. separation not possible? using with x1850. MacOs Monte Rey
geposted Tue 16 Nov 21 @ 9:40 am
You mean the 2nd SC6000 device follows the Deck selection of the 1st one ?
Can you go back to a previous Build and check if the issue is indeed due to an update ?
https://www.virtualdj.com/download/build.html
Or by update you mean OS update ?
geposted Tue 16 Nov 21 @ 10:46 am
Thank you bro. The problem was the new Virtual Dj update. Didn't know where to restore older versions. Thanks to the link I reloaded the last version and now everything is running as before.
geposted Tue 16 Nov 21 @ 5:09 pm
So, Build 6732 (previous Release) is working fine, but Build 6747 (current one) is not ?
Will try to check here, but only have a single SC6000
BTW, in Settings->MAPPING tab, what do you see as "Deck" for each device ? I believe you should get "Automatic(1)" and "Automatic(2)" for each of the 2.
geposted Tue 16 Nov 21 @ 10:24 pm
