I wanted to thank Virtual DJ Tech Support for fixing the issue I was having on not being able to "upload" podcasts...your recommendation worked!!! I did as you instructed, it fixed the issue.
If anyone else is having issues with not being able to "upload" podcasts to the server, the fix is: go to documents > Virtual DJ Folder and delete the "settings.XML file" or you can move the file to another location outside the folder. This RESETS the software settings, it doesn't affect your database files..
I'm now able to upload my podcasts...it's working 100%.
Thanks again, Jeff Pino :)
geposted Thu 18 Nov 21 @ 3:06 am
