Topic: update windows 11
What kind of problems can we have when updating to windows 11? in my case with the reloop touch controller? not only at the virtual dj level but also with the controllers that we have?
geposted Fri 19 Nov 21 @ 7:11 pm
at worst driver incompatibility
check with the manufacturer to see the status of that.
Hi,
here are my experiences: I updated to Win 11 on my Surface Pro 7 and ran 3 longer mixes (1.5h, 2h, and 2.5h) on my Denon Prime 4.
I used the camera plugin and video out to record the mix as normal.
No issues so far.
I have an old Reloop Touch somewhere. I will check, if there is any issue. Espacially with the drivers for the controllers screen.
Will post an update soon.
Cheers Jochen
Just checked Win 11 with Reloop Touch Controller. Did only a short check. But everything worked fine.
Did not install from CD. Just plugged it in and installed the stuff VDJ suggested.
Cheers
Jochen
