Topic: Disable BPM analyzer on track load
docb-djPRO InfinityMember since 2019
So how do I disable VDJ from changing the BPM on a track when I load it?
I am loading the track from my serato crate where I have analyzed and set the BPM to 170. VDJ thinks it's better and changes the BPM to 84.99. How do I prevent VDJ from doing that?
geposted Fri 19 Nov 21 @ 8:28 pm
I'm having the same issue.
geposted Sat 20 Nov 21 @ 1:21 pm
If you analyze the tracks before loading them to the deck, they should keep the bpm in the same range as set in the tag.
(The easiest way to have this done automatically from the browser is probably to enable analyzeSongsOnView)
geposted Sat 20 Nov 21 @ 1:31 pm
