Topic: Controlling Virtual DJ with an External Mixer
Hi, Is there anyway to control both decks separately on Virtual DJ with an external mixer with no usb? I was thinking I could use two separate audio interfaces with rca outputs on them? Which I actually tried to do by connecting two separate interfaces with outputs, to two separate channels on my mixer, but I couldn't get it to work, everything was coming through one channel.
Or do I actually need to get a controller to control each deck separately on Virtual DJ? And if so, do you have a recommendation? Thanks for your help! Scott
geposted Tue 23 Nov 21 @ 1:38 am
can be done, might have sync issues between 2 audio devices.
picture of your audio config attempts will help
You can't control VirtualDJ with a mixer - especially one with no USB. How are you expecting the MIDI signal to get from the mixer to VDJ?
What you can do instead, is send the audio of each deck out separately, via a suitable audio interface (i.e. one with at least four output channels). I assume that's what you meant although doing so is not "controlling VDJ".
timecode
