Hi Guys
I've got some karaoke files which i want to change the colour in the browser window so i can easily spot them, how ever they are all in sub folders ( by disc manufacture and disk number) and wanted to just batch colour change them all as highlighting every track in each sub folder will take me weeks, what's the easiest way to do this please?
DJ PK
DJ PK
geposted Mon 29 Nov 21 @ 10:48 pm
select all the files in each folder and goto to TAG EDITOR and change the color (do this for each Folder) unless all the file are in KARAOKE/SUB1, KARAOKE/SUB2 etc... then you can recurse then select all, TAG EDITOR, change color.
If all your karaoke files are in ZIP format, search ZIP and proceed above.
geposted Tue 30 Nov 21 @ 12:53 am
options, show only karaoke, type * in search, click a track, ctrl+a, rightclick tag edit.
geposted Tue 30 Nov 21 @ 4:14 am
