Topic: move a favourite into virtual folder
how to move a favourite folder into virtual folder, how is it supposed to be done?
I've been doing it outside vdj [only way I figured how to do it], feels like it should be a drag & drop job but maybe my idea for folder tree isn't that usual.
geposted Tue 30 Nov 21 @ 3:44 pm
You drag the Favorite folder over the icon of the Virtual Folder (a bit to the left side), until you see the up arrow on the left side of the red line , then drop
thanks, yeah that's what I thought, seems there's something in my settings preventing the red line appearing [just flattened my settings and it worked fine after]
I'll go digging see if I can find the errant setting.
*edit* found it [stupid boy] lockFolderOrder.
what do you mean? move a single file or a whole folder?
whole folder, it's sorted now, I forgot I had lockedFolderOrder on
