Ik have a new Hercules DJControl Starlight controller and the Virtualdj PRO Infinity license.
If a connect the Startlight to VirtualDJ then the sound of the decks (left/right) is always heard regarless the crossfader is on far left or far right position.
and when you select the crossfader on screen with your mouse pointer, then you see such a message "CROSSFADER value: Disabled". Is that maybe part of the probleem ? why is it desabled?
please. help.
please. help.
geposted Wed 01 Dec 21 @ 11:28 am
I've found the setting "Crossfaderdisabled = YES" into "options & Tweaks".
I've changed it to NO and the Crossfader is now working as it should be.
Why is "Crossfaderdisabled = YES" the default?
geposted Wed 01 Dec 21 @ 11:36 am
It's set to No by default of course. Most likely, you have accidentally changed that at some point.
geposted Wed 01 Dec 21 @ 7:33 pm
