gang -
i still love and use 're-condensed' skin. it has 4 buttons that can be customized.
how can i make a simple stem pad on/off per deck?
when i do stem_pad 'Vocal", it kills vocals for both decks. don't need all the fancy stem features, but basic on/off per deck.
geposted Thu 02 Dec 21 @ 4:20 pm
deck all mute_stem 'vocal'
geposted Thu 02 Dec 21 @ 4:24 pm
thanks.
will this work for each deck? press my custom button to enable stem per deck?
geposted Thu 02 Dec 21 @ 4:29 pm
you said all decks, if you want per deck, just don't include the bit,
deck all
deck all
geposted Thu 02 Dec 21 @ 4:40 pm
stem_pad 'vocal' should do the job but in case it's an old skin without <deck> containers, you may have to add deck x in front, and probably assign 2 buttons (1 for each Deck)..
deck 1 stem_pad 'vocal'
deck 2 stem_pad 'vocal'
geposted Thu 02 Dec 21 @ 5:04 pm
that works, but... the effect is applied w/o pressing the button.
i'm looking to play normal and apply only for duration of button. i know a new skin might be better, but just love this really old skin.
and later maybe assign a random button on my beloved dac-3 (yes, a dac-3) :)
geposted Thu 02 Dec 21 @ 6:03 pm
add while_pressed
deck 1 stem_pad 'vocal' while_pressed
geposted Thu 02 Dec 21 @ 6:23 pm
There is a good YouTube video on this.
geposted Tue 07 Dec 21 @ 12:09 am
