As the title says, I have mapped a custom key command to effect_button 1 and effect_button 2 but the effect buttons don't react to my key commands.
Okay, meanwhile I have found that the effect button on the active deck is working.
Now I would like to set up a key command for the master effect.
Can anyone please help me on who to map a command for the effect buttons of the master effect, please?
Thank you!
Thank you!
geposted Mon 06 Dec 21 @ 11:23 am
This will toggle on/off the second button on the first fx slot (the visible one) on the master deck
deck master effect_button 1 2
geposted Mon 06 Dec 21 @ 11:53 am
Thank you! The expression deck master before effect_button has helped. Now it works on the master effect. :)
geposted Tue 07 Dec 21 @ 7:15 am
