Topic: virtual dj is already running message
So, recently, my VDJ will not open and when I click on the shortcut, I get a message saying that Virtual DJ is already running. It appears that VDJ will only open properly if I am connected to the internet, which is not always possible at some venues. Is there a setting or something in VDJ that will allow it to work without being connected to the internet? I am not sure what happened as I have been using it all season long and just recently starting getting this message?? I welcome any insights or tips..
geposted Sat 11 Dec 21 @ 3:30 pm
VDJ will run just fine without an internet connection. It's designed to do that.
The message you're seeing is not related to lack of internet connection. Check Task Manager (assuming you're using Windows) and close any VDJ executables you see listed there.
