Topic: Numark Party Mix MKII
Hi all :-)
I'm just starting out with virtual DJ and have been using MIXX thought the years.
I'm not at a point of buying a DJ controller and having been checking out a few possible options.
Just wanted to know if virtual DJ supports 4 decks on the Numark Party Mix MKII ?
If not which entry level controller would be a good choice for using 4 decks in virtual DJ ?
Thanks a million
Den
geposted Sun 12 Dec 21 @ 12:23 am
Party Mix MKII not 4 deck supported natively, given enough remapping it could
[given enough remapping any device could support any number of decks] but realistically 4 decks is slightly beyond the bounds of an entry level device, however, I don't think it would be much more than a case of left deck swapping 1 & 3, right deck 2 & 4 and the script exists to do that.
@Locodog .. Thank you so much for the reply.
So given the info you supplied would it just be a case of a button press to toggle between the decks ?
You also mentioned a script.. is it a part of virtual DJ ? (Apologies for the newbie questions, I'm still finding my way around the product.
Den
that is the case, probably best a keyboard button or a click on the skin as the PM2 is limited on buttons.
