Topic: bug sampler_rec loop
Hello everyone, I report this as a failure since I have realized that when the sampler_rec command is used, the saved sampler is saved with loop or without loop indistinctly, and there is no way to avoid it, there should be some configuration to be able to decide this, sometimes I record a sampler and I don't want it to repeat itself and I have to be editing the sampler. and on the contrary, sometimes I need it with a loop and it is not with a loop
geposted Sun 12 Dec 21 @ 2:02 pm
no response ?
geposted Thu 30 Dec 21 @ 12:24 am
