Topic: bug order sampler
Hello, I report this as a bug that I found in the use of sampler, when I drag the samples to the bank in a disorderly way eg PAD 1, PAD 5, PAD 8, the software shows them on the corresponding pads 1,5,8, but when show in list format lists them 1,2,3, the problem with this is that when using the pad_5 command it does not find the sampler, because it is "empty", my sampler is actually on PAD 2, since the software orders the sampler in order of arrival and does not respect the position that one assigns, I leave an image of the example
geposted Sun 12 Dec 21 @ 2:18 pm
no response ?
If dragged as in the screen shot pad 5 should work if the controller you use it on also has a 4x2 layout
