Topic: FX1/FX2 buttons on DDJ-SX2
KronsterControlleristMember since 2010
Could someone place give me the correct key mappings for the FX1 and FX2 buttons on the DDJ-SX2 controller so they properly clone the effect choice? I am able to map them to something else and they light amd work just fine... meaning this is a software issue and the factory default settings do NOT function properly. The default in the mapping shows:
FX1_Assign Action: effect_clone 1
FX2_Assign Action: effect_clone 2
These settings DO NOT light the button when pressed and don't seem to close the effects over.
Thanks!
geposted Sun 12 Dec 21 @ 5:25 pm
DrDave1Home userMember since 2022
I have the same problem with the same controller SX 2
geposted Sun 23 Apr 23 @ 7:18 am
Still no answer to this. Can we just reprogram it for something else?
geposted Tue 03 Oct 23 @ 2:14 am
You can remap the buttons, yes.
However there's nothing to "solve" here.
Effect_clone action is a momentary action, not a state/toggle and thus it doesn't return a value to turn on the LEDs. And the action itself (cloning the effects slots used in one deck to another deck) works as it should.
geposted Tue 03 Oct 23 @ 11:17 am
