Topic: Asus Rog G712
geposted Mon 13 Dec 21 @ 12:39 pm
one other question. Would a AMD processor be ok to use for stems. Video card will be rtx 2080 or 30...
Better with Intel & Nvidia for stems as they can run on the GPU. Wouldn't personally recommend AMD.
But since you've said you're buying it it's a moot point.....
Thanks for your reply. The link is Intel and the price seems reaonable.
The video card is rtx 2070 but is there a big difference with the 30 series. Again Im only playing audio nothing else.
Should be fine then.
Thanks again.
Recieved my Asus Rog strix G712 machine. Its brilliant. Very happy with it.
spen thanks for posting after you ran it as lots of people are looking for affordable solutions and knowledge
no worries. cheers
