I am expirience a problem with the search field.When I open the programm and search a song for the first time it displays searching and find the result after 10 15 seconds.After that it works fine and at the second third ..search it finds the song immediately
geposted Mon 13 Dec 21 @ 2:28 pm
Most likely it's because one of your hard drives (most likely external, mechanical) is sleeping before you start searching.
Therefore, VirtualDJ waits for the drive to wake up, spin, read the database file from disc and pass it over to the program.
Most likely (depending on your power saving settings and/or the external HDD firmware) you will have similar lag(s) the first time you try to browse a folder on the given drive, or load a song from it.
The solution on most cases is simple: Adjust your computer's Power Saving settings.
geposted Mon 13 Dec 21 @ 8:41 pm
