Hi all!
While I am happy that the new "radio" automix fade type was implemented, I am not very happy with the way it works. The reason is this:
When track A reaches the end of the song there is no "smooth" fade out, but a sudden drop of volume (I would say of approx. 30-40 %) about 1-2 seconds before track B kicks in. This is especially disturbing when playing ambient kind of songs. This makes this transition type quite useless for me.
This happens regardless of the fade length (16s or 8s) and there are no automix POI set in any of those songs.
Is there a solution for this problem or a known workaround?
Thanks!
Thanks!
geposted Thu 16 Dec 21 @ 7:46 pm
I have issues with it cutting off songs too soon.
Sent @adion a PM but haven't had a response yet.
It hasn't really worked properly since day one.
geposted Thu 16 Dec 21 @ 7:58 pm
Thanks Kradcliffe, that is my impression too. I have tried it over the last years a couple of times, but it never worked well. Would be fantastic if this would be fixed at some point.
geposted Thu 16 Dec 21 @ 8:12 pm
